Not actually a bug, more of a warning...Having played about with 2.0 ( looks great guys, really looking forward to final version...brill!!! ) I fidn that all my pre-prepared decks ( orginally created in 1.51, then tested in 2.0, some mods and saved in 2.0 ) will now no longer play in 1.51...!!!! Arghh 2 days till a gig and most decks screwed.....My fauly should've check...watch out guys.
Still 2.0 looks the bus, keep rockin guys, great job!
resolume 2.0 beta: post your bugs here
astermic_
meek_
Ive had a bug where clips freeze up now and then, when u are controlling them with the resolume ftt audio analysis. This is fixed by removing the clip from the output window, clicking another clip, and then loading the one which got stuck back up.
Also the key not working properly to toggle back and forth is really annoying !!
Update soon please !
Opto22_
I've been working with this program on and off for a week or so and I"ve got a question, are there any plans to implement an assignable arpegitaor that will clock to external MIDI Clock? Even the Chaos engine should be able to clock to external MIDI Clock, I don't see this option anywhere, does it exist?
I also noticed that it is too easy to trigger the record function, there should be an option to toggle a warning to the controller if they really want to record, because if you don't know it's recording, it appears as though the program has locked up (i.e. not being able to select one of the channels and the video appears to stop running in the other channels).
I really like the program though.
I'm going to experiment using better audio cards to see if better quality A/D convertors allow the audio trigger to trigger avi's faster and more accurately.
(of course I'll post my results here)
DinkyToys_
DinkyToys_
Ren Yoneyama_
Ren Yoneyama_
Ren Yoneyama_
macksign_
Hi all,
here is my list of bugs so far,
the scroll wheel of my logitech usb mouse does not work to scroll through files.
the files do not appear sorted (alpha etc.?)
i can not group effects in seperate folders to have my favorites together
the timeline sometimes freaks out clips are not played until end
saving decks with in and out points does not work as it should
Is there a bug fix available or planed?
In hope,
macksign
In hope,
macksign
