known issues so far:
- multiple output screens do not go fullscreen (windowed does work)
- when changing the layer order the chaos is confused
resolume 2.0 beta: post your bugs here
Trunx_
Trunx_
metaprofessor_
cat_
Yup to the thumbnails,
Toggle reverse ( ) doesnt work, it changes the direction in the deck but doesnt affect it in the layer
In fact preferences haven't been saved either, I saved a deck after changing things too, just in case. this happened to key prefs, folders in the freeframe section, and things put into folders.
Ive also had clip length not being displayed correctly in the Layer section (still OK in the Deck) and loops only playing that section, this happened after a while with old decks, so I dont know if thats an issue or not.
Got a USB and Firewire in going at the same time though, which was nice.
videoteque_
I have several fatal problems...
I can't see any video, nor preview it. I have all my files encoded in Indeo 5.11 I am downloading the last DirectX version.....
Resolume can't create a double screen setup. I choose my parameters, click Apply and get absolutely ignored...
Thumbnails doesn't refresh when I add an effect. The thumbnail dissapear.
My Resolume is like in pause, videos don't play...
pifco_
barny_
