REQUEST: Play same Video on more than one layer
dbassix
Post by dbassix »
Hi Guys,
while triggering videos through the "Active Layer" mode, i can play a clip only on the first activated layer. When i select another layer, and want to play the clip there nothing happens, and i have to unload the clip in the other layer first. I need to play a clip on several layers, without using the layer router or having the clip twice or more in my composition. (e.g. in Arkaos when u load a clip into several layers, they all play with same speed/position, thats exactly what i need!)
Cheers
pfelberg
Re: REQUEST: Play same Video on more than one layer
Post by pfelberg »
You can just add another instance of the same clip in an empty slot in the same deck.
Although I´d like that also.
+1
dbassix
Post by dbassix »
That's exactly what i don't want :?
HerrNieDa
Post by HerrNieDa »
it should work with the layer router!
dbassix
Post by dbassix »
As i said, it works with the layer router, but I can't use it in my setup.
I'm controlling Resolume through DMX. My setup has 3 Layers with 256 clips on each layer (all layers have the same clips). So i can put any clip on any layer to mix. I don't want all the clips 3times in my composition, so thats the reason for this problem. And when triggering clips to active layer, i can't play a clip on layer1 with the same clip on layer3 for example.
Your request has been noted.
dbassix
Post by dbassix »
Thanks ;)
