Resolume freezes on load when using GPU affinity
Trypta
Post by Trypta »
I'm sure most people haven't come across this problem but when loading Resolume using GPU affinity with Nvidia Quadro cards Resolume will hang if the primary monitor is not connected to the GPU that Resolume is binded to (on Windows).
Basically with Quadros you can set which GPU an app uses either by right clicking on the apps icon and selecting "Render OpenGL on ..." or setting it up in the Nvidia control panel so a program always loads on a specific GPU.
There is an easy work around, just change the primary monitor to the monitor Resolume is loading on but I thought I would post this anyways just in case it is an easy fix.
cheers
Keith
