video card question
sidraea
video card question
Post by sidraea »
hey. this might be a stupid question. i dont know too much about computers...my graphics card has 4 outputs on it. two dvi, an hdmi and (i think its called) a display port. i usually use two monitors plugged into the two dvi ports and my projector plugged into the hdmi. i'd like to use 4 projectors for a show. if i plug my monitors into the motherboard (dvi and vga) and plug the 4 projectors into the video card....will resolume render video with the graphics card or will it try to use the motherboard? thanks to anyone who can help.
Re: video card question
Resolume will use the card that has the interface on it.
