after trying superspeed software's ramdisk xp pro for intel processors, i can say with certainty that having resolume load the clips to RAM would be 100x's better than using the disk continuously.
i've been using a 120 GB western digital special edition hooked up to USB 2.0 on my laptop (not exactly slow!), and it still seems to lag when i run resoume 2.0. when i tested with ramdisk everything was faster.
the problem with ramdisk for me is that i have 5 GB's of indeo avi clips, and there is no way in hell i'm going to fit that in RAM! if i was to try doing a gig with ramdisk i would have to keep transfering and deleting from the WD to RAM - which isn't all that fun.
the solution is clearly to have resolume cache the clips in RAM!!! consider that a request to bart and edwin for the future of resolume.
[Edited on 31-10-2004 by metaprofessor]
i just tested RamDisk xp pro
I totally agree with you, you can see my post on this there : http://www.resolume.com/discussion/index.php
