Video Input on a Laptop
Does anybody know of Laptops that come with VIdeo input on them stock? I have seen that the 18inch Alienware has a HDMI input and output on in. Are there any other laptop with this or ones I could build? I have built many desktops and could do a laptop. Any external cards that dont limit me to not being able to output?
Re: Video Input on a Laptop
Hi clanoue,
I'm owning a Alienware m18x R2... and yes..it do have an HDMI in. But it's directly linked to the Monitor of the Laptop..so you can use your notebook like a display. Not more or less. It's not possible to use this HDMI-In with any software.
Hope that helps!
greetz
Hope that helps!
greetz
Do you like outlines? Easy Outliner on Juicebar Re: Video Input on a Laptop
Thank you very much for the info. And that sucks the big one....
infact - Laptops still suckclanoue wrote:Thank you very much for the info. And that sucks the big one....
Yes they do. I have a 19" 4unit high rackable computer case and a rolling gator rack to put it in. But I need to build a computer to put in it and it will never be as quick to setup.
