Hi guys!
I`m just starting in the resolume world and i was wondering...i`m using ir mapio to slice my shapes but i can`t get resolume to play my video like one in all the slices.
i want to map a cube, wich i did but when i select the video , it plays the same instance of the video in all sides.
I want the video to play all sides of the cube like one. is this possible? plugins, effects or configuration?
WHOLE IMAGE IN ALL THE SLICES
- Stickygreen
Re: WHOLE IMAGE IN ALL THE SLICES
you need to tell mapio (now called Visution) to show different parts of the entire image in different parts of the output.
You can do this by selecting the input tab at the top left of the mapio screen. Then draw your desired mapped sections in there as well, this way, you will tell each input section to go to a different oputput section. Adjust accordingly to get the image to look the way you want it to.
