I was wondering if it is possible to make a Quartz patch that I can input layers into or is this a feature that needs to be added?
SIMPLE EXAMPLE:
Quartz patch built with 4 Billboards and output with a different layer running on each billboard, but within Resolume.
Thanks.
Quartz Image Input
Re: Quartz Image Input
No. Here's a workaround: viewtopic.php?f=12&t=10159I was wondering if it is possible to make a Quartz patch that I can input layers into
Is it a feature that you *want* to be added? Yes. Is it a feature that *needs* to be added? No, not really.is this a feature that needs to be added
