Resolume Powered Video Mixer
DayVeeJay
Post by DayVeeJay »
I dearly miss using my trusty V4 but with technology advances, video mapping, and multi screen setups, its not very practical. So I'm interested in building a Mixer powered by Resolume. Here's what I have planned out in my head:
Shuttle sized PC
Quad output video card
2x Black Magic Intensity Pro Capture cards
2x Cheap USB capture cards (you never know when you'll need it...)
Cheap USB/MIDI dongle
V4 as a control surface
Lilliput Touchscreen - 7" @ 1024x768
Possibly a Max/MSP interface to be displayed during performances?
The primary role of this machine will be mixing between capture cards, applying effects and occasional playback of logos. I currently have two licenses for Arena, one for R3, and a Mapio license. I'd like to use R3 and Mapio for this project. My main concern is stability. Any thoughts, concerns, comments?
HerrNieDa
Re: Resolume Powered Video Mixer
Post by HerrNieDa »
especially in older versions resolume isn't that stable with midi...
don't know but maybe it's better to use a touchosc/lemur interface via osc, problem is you don't hold anything in your hand,...
just give midi a try but if it's unstable maybe try a osc variant (you can also try to convert the midi to osc adresses, so you can use a midi controller and don't use midi in resolume)
also the one or other effect is maybe a stability point...
try it out if it work for you ;)
