I'm currently having a problem I can't really explain.
config: PC W7 64-bit
R4.1.4 Avenue.
3 x 1920x1080 outputs on a NVidia GTX 680 (1 for control 2 for display)
I had the problem on 2 several machines (Mac then PC)
one of my output shifts vertically at some point after flickering.
(not visible in the Advanced Output interface though)
Is there any similar problem that happened in the past with Avenue not being able to handle 2 full hd outputs ?
I'm checking all the hardware on the other hand obviously
thanks a lot !
