all screens flash...
disconappete
Post by disconappete »
when adding content during playback. if i drag content into the clips area all of my video outputs including control flash. I never had this issue with previous versions. It doesn't result in a system lockup or anything terrible just a blank frame. anyone else have this issue?
thanks!
vj granda
Re: all screens flash...
Post by vj granda »
viewtopic.php?f=12&t=9167
Specially please, read this...
- Only if you can't find your problem on the forum, create a new topic. When creating a new topic, please provide the necessary info on your hardware and software setup (operating system, graphic card, Resolume version, codec and filetypes used).
disconappete
windows 7
Arena 4.1.4
3.5ghz dual core
16gig dual channel ram
7200rpm drive(programs/os)
120gig SSD(content)
HD7770 GPU
control monitor is hdmi>dvi
Main one is DVI
Main two is mini DP>DVI
sometimes i convert and run analog signal, but mostly all digital anymore.
during playback, all outputs including control will flash for one or two frames when i attempt to add more content into the clips section. everything is A-OK if i do not add ADDITIONAL content during playback, but even dropping a small JPEG is causing issues, I did not have this issue in previous versions....
kmifflin
Post by kmifflin »
I've having the same issue on a gig this. Only happens when I try to add a clip.
Todays setup
i7
16 GB Ram
hd7970
triplehead2go Digital Edition
7 projectors
1 control monitor
Composition 2560x1920
Is it possible for either one of you to record this happening?
kmifflin
Post by kmifflin »
Sorry. Too late for me. I've already finished the gig. One day fashion show type of thing. I did noticed this only happened on old stock clip I used. They were DXV but I had converted then maybe 2 years ago. I had to drop in a DXV clip that was 2560x1600 during show and everything was smooth.
The only other factor I can think of is I did power down between flashing and not flashing.
If it wasn't for this I wouldn't have though twice about it as I was pushing the limit outputs, 8 with a triplehead2go expanding my hd7970.
