Advance Output - Black/White Clips
dirtyjohn_lv
Post by dirtyjohn_lv »
Pretty sure this has to do something with the BM UltraStudio being used as an input device, but ....
3820 x 1080 composition
Layer 1-4 with an x-position of 960
Layer 5-8 with an x-position of -960
With my current setup and advance output, the slices work fine. Mapped to different parts of composition instead of using routing.
If I do NOT maps slices in advanced output and instead use input routing for the "Hotel Feed", all clips go black/white depending on content.
UltraStudio SDI input source on Layer 1, Advanced composition (3 x 1280x720), Route layer 1 to right most screen.
Camera input goes black. As well as all other video clips. Logos/Images go solid white (preview and output).
I have to physically restart Arena to get clips to work normally.
Using Desktop Video 9.7 (NOT 9.7.1, capture devices randomly crash under updated DV with an Intel USB3 chipset)
My "Advanced Output" without layer routing
Code: Select all
<screenSetup>
          <default enabled="0" displayNum="-1" fullscreen="0"/>
          <screens useAdvancedScreens="1" outputDisabled="0">
            <simpleScreens>
              <versionInfo name="Resolume Arena" majorVersion="4" minorVersion="1" microVersion="5"
                           revision="5372" id="1"/>
            </simpleScreens>
            <advancedScreens presetId="13567732">
              <screen outputDeviceName="DISPLAY4" outputDeviceId="DISPLAY4 - NVIDIA Quadro K2000M \Registry\Machine\System\CurrentControlSet\Control\Video\{59D05361-9AAD-4D59-8F89-4C3F8DD32181}\0000"
                      enabled="1" fullscreen="1">
                <name value="Screen 1"/>
                <slices>
                  <Slice isEnabled="1">
                    <name value="LED"/>
                    <type value="0"/>
                    <rect l="0" t="0" r="0.5" b="1"/>
                    <warper width="4" height="4" angle="0" subdivision="21">
                      <verts>-0.0222222209 -0.0111110741 0.214814827 -0.0111110741 0.451851845 -0.0111110741 0.688888907 -0.0111110741 -0.0222222209 0.122222252 0.214814827 0.122222252 0.451851815 0.122222252 0.688888907 0.122222252 -0.0222222209 0.25555557 0.214814827 0.25555557 0.451851815 0.25555557 0.688888907 0.25555557 -0.0222222209 0.388888896 0.214814827 0.388888896 0.451851845 0.388888896 0.688888907 0.388888896 </verts>
                    </warper>
                    <softedge/>
                    <mask angle="0">
                      <verts>0 0 0 0.333333343 0 0.666666627 0 1 1.77777791 1 3.55555558 1 5.33333349 1 5.33333349 0.666666627 5.33333349 0.333333343 5.33333349 0 3.55555558 0 1.77777791 0 </verts>
                    </mask>
                  </Slice>
                    <name value="TV/LED"/>
                    <type value="0"/>
                      <verts>1.75555563 -0.0111110806 1.99259269 -0.0111110806 2.22962976 -0.0111110806 2.4666667 -0.0111110806 1.75555563 0.122222275 1.99259269 0.122222275 2.22962976 0.122222275 2.4666667 0.122222275 1.75555563 0.2555556 1.99259269 0.25555563 2.22962976 0.25555563 2.4666667 0.2555556 1.75555563 0.388888955 1.99259269 0.388888955 2.22962976 0.388888955 2.4666667 0.388888955 </verts>
                    </warper>
                    <softedge/>
                    <mask angle="0">
                    </mask>
                  </Slice>
                    <name value="Hotel Feed"/>
                    <type value="0"/>
                    <inputSource value="-1"/>
                    <useLayerOpacity value="0"/>
                    <rect l="0.5" t="0" r="1" b="1"/>
                      <verts>3.5555563 0 4.14814901 0 4.74074125 0 5.33333397 0 3.5555563 0.333333343 4.14814901 0.333333343 4.74074078 0.333333343 5.33333397 0.333333343 3.5555563 0.666666627 4.14814901 0.666666567 4.74074078 0.666666567 5.33333397 0.666666627 3.5555563 1 4.14814901 1 4.74074125 1 5.33333397 1 </verts>
                    </warper>
                    <softedge/>
                    <mask angle="0">
                    </mask>
                  </Slice>
                </slices>
              </screen>
            </advancedScreens>
          </screens>
        </screenSetup>
