use sound in resolume by flash movies
once again cause nobody answered.
i need to use the sound of the videoclips for the show.no need to scratch it, just playing a good sample with sound on demand ,for example a intro. but resolume does not support sound, except the sound in flashmovies. so i tried to convert some clips into flash, that is no problem, i tried the export in after effects and squeeze does also well.so i have flashfiles with sound but resolume ignores the sound.
does anybody know, what resolume needs to accept the sound or know a good way to convert movies into flash ?
thanks das ben
again using sound by flashfiles
use macromedia flash
free 30 days trial on macromedia.com
load an event sound into the 1st keyframe
-> hope it works
greetings sikanda (http://sikanda.at.tf)
-> hope it works
