remember THOSE days... pre-SSD...
You might be an old VJ if ...
- digital:snot
You might be an old VJ if you remember spending hours trying to efficiently manage your RAMDISK system...
Re: you might be an old VJ if...
... you know how to operate an mx50.
...your standard glitch effect was a large magnet
you used an Amiga.
... u think tunnel and kaleidoscope are cool effects.
Re: You might be an old VJ if ...
...if you ever used a FUJICA 8P MASTERLOAD
Do you like outlines? Easy Outliner on Juicebar -
LXConcepts
...you know how to use film projectors
Lighting and media server design
- digital:snot
...intel indeo...320x240...
you used to render your anims frame by frame, using a frame buffer as Targa;
or record them to Betacam using a single frame controller.
your weapon of choice is a slide projector.
