Hello, I tried to map "position" to the P key on keyboard so when i press P and move the mouse the clip follows it. Easy oldskool thing. But in 4.1.6 on Mac it is somehow crazy: when i press P for the first time it is ok but when i relase it and press it again values for X and Y axes just jump to some crazy numbers so the clip disssapears from the screen! ?
It works the same way with rotate and scale (which I usually map to R and S keys)..
Why?
thx a lot
Key Mapping problem - R 4.1.6. on Mac
- ondrejsevcik
Re: Key Mapping problem - R 4.1.6. on Mac
Oh wow. Yes, that's not right. 4.1.7 here we go!
Thanks for the find!
