Hi Guys
I think that would be a great thing implement these features in Arena...
What do you think? might be all useful?
0 Ability of SELECT and DESELECT more slice/ mask/ crop to change parameters in one shoot
(on/off, duplicate, size, input source, layer opacity, luminosity adjustment ecc..);
1 New object type: TRIANGLE slice (=! 3 point crop) and CIRCLE slice;
2 Ability of GROUP more slice/ mask/ crop
(for manage large number of object);
3 Ability of ZOOM the view of input selection and output section
(think build map on ultrawide composition without zoom);
4 KEY shortcut to save, duplicate and rename slice/ mask/ crop;
5 Checkboxs for magnetic points, flip and preserve aspect when scaling slice/ mask/ crop;
Arena Advanced Output...
Re: Arena Advanced Output...
You raise valid points, and I'm sure that the majority of the people here will agree with you.
In fact, if you use the search function, you'll find that many others have requested and discussed these features before.
If you have anything to add to those discussions, I will gladly answer your questions here or in the appropriate thread.
