im just learning osc so i apologize if this is a no brainer or covered before.
i have a strobe effect on my composition and a button on my osc device that is supposed to un-bypass the strobe. in other words i push the button and the effect activates. but instead it always bypasses the effect when i push the button not unbypass -- does that make any sense? if so how can i fix this?
osc bypass
Re: osc bypass
There's two ways to do this.
The most correct would be to send the opposite values. So instead of sending a 1 when you press the button and 0 on release, send a 0 on press and 1 on release.
If you don't need control over the opacity of the strobe, you can also send your OSC to the opacity value of the strobe instead.
Re: osc bypass
That worked perfectly reversing the 0-1 thanks man. I swear i tried that before but maybe I had a dyslexic moment.
