File relocating
dirtyjohn_lv
File relocating
Post by dirtyjohn_lv »
Moving files between computers with different drive setups, relocate won't open a file dialog
Computer A has drive C and D, with content stored on D
Computer B has drive C only
Trying to relocated on Computer B causes nothing to happen probably because it can't find drive D.
Maybe if it can't find a drive, default to computer system drive?
Re: File relocating
Sorry, it took us a while to find two computers for testing with this (it's amazing how many machines come with two drives by default these days).
This is indeed the cause of the mysterious 'relocate not opening' issue. Thanks so much for figuring it out and letting us know!
nrcbtnue
Re: File relocating
Post by nrcbtnue »
First of all, I want to say Resolume Arena is very cool program....BRAVO.
I have been working on a Windows 7 and 8 systems. I just bought Arena 2 weeks ago. I had been working furiously on a big project using a unregistered version of Resolume Arena and it all seemed to work well (that is why I eventually bought it). It came to show day a few days ago and I put the newly created composition in the new registered show computer with my purchased serial number and tried to relocate the files and got this File relocating problem - dialog window NOT popping up. I tried on XP, Win 7 and Win 8 computers with the same problem.
It seems that you are aware of this now. This is an extremely BIG show stopper for me :cry: and has caused a lot of problems at this point in time.
Is there a known workaround yet ?
Many thanks!
Re: File relocating
Here a workaround for you:
- Make a backup of your Resolume showfile wich works fine on computer A
- Move your Clips with their foulderstructure to your computer B
- Open your showfile with the a texteditor on computer B
- Use the search function and search for a path of a clip from computer A
(example: D:\content\show\Festival_bam_2013\clips\laser_01.mov)
- Copy a part of your path wich is global for all your used clips.
- Use the search&replace funktion of the texteditor
search: D:\content\show\Festival_bam_2013
replace with: C:\content\show\Festival_bam_2013 ( << the new location on computer B)
Yes to all! Save!
Tell me if this works for you?
Greetz
nrcbtnue
Re: File relocating
Post by nrcbtnue »
:!: Big big thank you!
That worked! You saved me a week's work!
Re: File relocating
Here is my bank account number: 607374584863 307545 :D
Glad that I could help you!
Enjoy!
cologne
Re: File relocating
Post by cologne »
"Supermarco" ... because you helped a lot - me also. I had the same problem with different usernames on two computer A & B. Thanks! Juhu :-)
Macbook Pro (Late 2013) 2,3 GHz Quad-Core Intel Core i7 | 16 GB RAM | NVIDIA GeForce GT 750M with 2 GB GDDR5 | OS X 10.9 | 1TB SSD | Resolume Arena 4.1.8 | Music: Traktor Pro 2 with Audio Inteface DJ 8
drazkers
Re: File relocating
Post by drazkers »
cosmowe wrote:Here is my bank account number: 607374584863 307545 :D
Enjoy!
