-different Presets for the Advanced Output and some Kind of Parameter Morphing between them
-parameter editing via DMX /Midi/Osc table
-solo and mute switchable via DMX/Midi/Osc (perhaps with Autofade/Transition feature,like in the layers )
-Autopilot for all that (or a small sequencer ??)
Advanced Output Morphing / DMX, OSC Editing
movebandit
Re: Advanced Output Morphing / DMX, OSC Editing
Presets can be saved and loaded via the top left drop down. Parameter morphing would be nice, but it's not sure if and when it will become a feature. It becomes quite complex when you consider different presets can have a different number of slices/masks and then each slice/mask can have a different number of warp points.-different Presets for the Advanced Output and some Kind of Parameter Morphing between them
Both of these have been discussed before and on the to-do list.-parameter editing via DMX /Midi/Osc table
We like to think big, but we need to take small steps(perhaps with Autofade/Transition feature,like in the layers )
