OSC BPM sync from Max for Live
Lupavision
Post by Lupavision »
Hi all,
We are trying to set the BPM in Avenue from Ableton Live via Max for Live patches using OSC (http://resolume.com/blog/8717). One computer is running Ableton and the other Avenue. They are linked through a wireless network.
So, we have clips being launched via OSC, but have had no luck syncing BPM of the video clips in Avenue with the sound in Live. Has anyone had any luck doing this?
Thanks in advance.
Re: OSC BPM sync from Max for Live
You are in luck!
Clock info did not get sent via OSC in the original M4L plugsins. But Matias recently made an update, which *does* send sync and start/stop info!
Get it here: viewtopic.php?f=11&t=8717&p=32131#p32131
