How to capture video output
How to capture video output (HDMI or vga) from laptop 1 to Laptop 2 (via usb)?
Re: How to capture video output
You can use a Blackmagic Intensity Shuttle for USB 3.0
1. You connect this device to your laptop 2 using the usb 3.0.
2. You connect the HDMI output of your laptop 1 to the HDMI input of this device.
3. Under the sources tab in resolume (running on laptop 2), you will find the blackmagic intensity option which when you drag on to a clip location and click on it, should show your laptop 1 feed.
Thankyou!
Wich video card for desktop pc can record video output signal in high quality?
If you are using a Mac, you could use syphon recorder
3Media servers i7 860 8GB RAM 240GB SSD Nvidia 760
1Media server i7 7800X 16GB RAM 240GB SSD Nvidia 1080
1Media server dual Xeon E5 2650 V2 32GB RAM 240GB SSD Nvidia 1080 + 970
1MacBook Pro 15 Retina i7 16GB RAM 512GB SSD Nvidia 750
