Replace file
Replace file
When I modify a movie file in for instance After Effect, but I keep the same DXV codec, the same duration and the same file name of the movie, should I import the movie again to Resolume, or does Resolume play the new movie file without problems?
Re: Replace file
You have expended more time writting this question than trying it by yourself...
Electroguepard
Re: Replace file
If you don't change aspect ratio, duration... etc, and you are only variating content, you don't have tor import again. But as granda says, better try, because you can discover other things.
The software must be abused by users (not sexually
