video input
fluido
video input
Post by fluido »
hi all,
does resolume manage 2 video inputs (ex.:1394 & vivo card) at the same time?
or two layers with the same source but different fx mixed between them?
If yes tell me how, 'cause I need it for yesterday ;)
thx
.f
yes you can use as many live inputs you like and you can also inters a live input as you like in the deck so you can runn the same source in multiple layers with different effects ;-)
you can find the live inputs under capture drivers in the sources tab. Just drag the one you want to a channel in the deck and you set to go.
