It would be great if there was an option in advanced output where rather than using the add points to warp the output you could double click the edges (and even middle) of your slice to add a node point - as per the masks.
At the moment I have a project where I need to just 'pull' the very edges but need to add so many points to get a node point near where I need to be. Then I have to adjust all the nodes that I have added.
Not sure if this is taken care of in the great V5 redesign or is something that you can add before my event in two weeks
Thanks,
Tim
