newbie question about mapping
damstraversaz
Post by damstraversaz »
Hi
first sorry for my poor english..
I'm first a musician , and using resolume with music for digital arts. I'm just begin to explore mapping (for some micro mapping tests), and as a non VJ or visual artiste ,I have a noob question about this :
On the post your mapping video topic , there is some amazing work with resolume. I'm not trying to do this of course, but really like the "running" lines or running videos, from left to right or up and down. Could you explain me how to realise this with resolume ? there is surely several ways for doing this.
thanks a lot for reading
Damien
digital arts:
http://www.damientraversaz.com/#!art-numerique/c1s43
music for dance, documentary and digital arts:
pfelberg
Re: newbie question about mapping
Post by pfelberg »
Damien,
You are taking about two distinct things.
First you need the proper content; animated lines, for instance.
Then you need to map this animated clip into different surfaces to achieve the desired effect.
First things first: You are no visual artist, but you still have to find or buy some animated lines clips. Then, try some tutorials about mapping. Bring your questions, difficulties and then we will guide you through the available solutions. ok?
damstraversaz
Thanks a lot for the answer, I will find some lines clips and will do some tests.
thanks again !
digital arts:
hive8
Post by hive8 »
As for animated lines, there is a plugin for that right in Resolume which you can animate them in realtime. Should be under sources FFGL if I am correct.
damstraversaz
exactly, that's actually what I'm using for creating lines, it's very useful !
digital arts:
