- Install the drivers of the controller.
- Plug-It in
- Open Resolume
- Open the preferences
- "Midi" / Check the Midi Input box for your Vj vontroller
- Close the preferences
- Choose -> mappping/edit application midi map or. edit composition midi map (why? --> MANUAL)
- Now click on one of the highlighted fields you want to map.
- Move the knob or fader on your controller
- Voilá: You are now able to map
- To exit the map-mode - press ESC
As far as I know, those jog wheels will send sporadic MIDI information unless you're using its first-party app Arkaos GrandVJ. The rest of the controller should work fine.
