import photos
yochee
import photos
Post by yochee »
any tips how to import photos to resolume in a fast way? i got a folder with photos, which is updated with new pics during my gig .. but switching folders is a mess
thinking about a flash app or something similarly easy (got a Win7 laptop)
thx !
yochee
Re: import photos
Post by yochee »
maybe with a flash slideshow maker or smthng?
Re: import photos
On top of the filebrowser you have A & B buttons... just direct your B presetlocation to your picture folder and leave it there. Your A preset is for your clips.
If its time to import photos click on B mark all and drag them into your composition.
Greeeeetz
yochee
Re: import photos
Post by yochee »
well, i think you didn't get me right.. i am vjing with resolume since forever or so.. i know these A/B buttons :roll:
the thing is, the image folder is getting updated with new images during the gig, so i would rather need "update" buttons for the folders (or i have to switch to another folder and then switch back to my image folder, which always takes 2 clicks..) or i thought about a decent "flash image slideshow clip", which just imports the new images in that folder by itself to the "flash clip". something like the "flash rss importer clip" that comes with reso, but for images ;)
update buttons for the file browser and sources list would be useful anyway!
Re: import photos
oh - Yes I got you wrong.
Hmm... there is a sort of update button. If you want to update B click A and back to B. Updated.
Maybe that helps you a bit.
Greeetz
Thelooca
Re: import photos
Post by Thelooca »
yochee
Re: import photos
Post by yochee »
@cosmowe. yp i c, my fault. it doesn't update the folders when it is the same on a/b, when it is different folders. it updates when changing. thx!
yochee
Re: import photos
Post by yochee »
@the looca, yes thanks! i though about something like that.. but this one needs a filelist to import the fotos and i am not too good at programming flash.. this wil stay construction area till i finished writing my diploma :D
