New Laptop (check it pls)
He2neg
Post by He2neg »
I´m on my way to buy a new Laptop and use Arena 4 on it.
Here ist the setup and what i ask you all is to take a look and give advices on parts of it.
If s.th. better is needed or if s.th. is not nessecery.
Also other Shops / Models / Components advices are welcome.
XMG P503 PRO Gaming Notebook 39,6cm (15.6")
• 39,6cm (15.6") Full-HD (1920*1080) Non-Glare
• NVIDIA GeForce GTX 770M 3072MB GDDR5 [compare to 680M ]
• Intel Core i7-4700MQ - 2,40 - 3,40GHz 6MB 47W [good enough?]
• 16GB (2x8192) SO-DIMM DDR3 RAM 1600MHz Crucial [ possibility of "Vengeance" or "Ballistix Sport"] ?!
• 120GB SATA-III SSD Samsung 840 EVO Series [Windows & Arena & Content]
• 500GB SATA-III 7200U/Min WD Black [rest of stuff]
Thx 4 your time and brainpower.
sleepytom
Re: New Laptop (check it pls)
Post by sleepytom »
looks pretty good to me.
I would try and get a bigger SSD though, 256 would be much better, get the Samsung 840 Pro if you can, its a better technology than the evo. Windows 7 is annoyingly big, and lots of applications now run to tens of gigabytes of install space.
He2neg
Post by He2neg »
Thank you, i think a 256 pro will be possible.
What about the different between the 4gb 680m and the 3gb 770m ?! Some remakable differences ?!
Is it better to set up a 32bit system for Resolume ?!
i read s.th. about it in this Forum and didnt understand it in total so just here the question (y/n)
~Berlin~
sleepytom
Post by sleepytom »
you won't really notice any difference between the 2 GPUs.
resolume runs fine on 64bit windows, don't bother installing a 32bit OS in this day and age.
jd1029
Post by jd1029 »
You can check to buy laptop under 40000 Rs.
