Auto Loop Plugin
kmifflin
Auto Loop Plugin
Post by kmifflin »
It would be great if I could make any clip loop.
Right now I do this in Final Cut.
Split clip in half
Swap the front and back clips with each other
cross the centre
It would rock if this could be coded into resolume
HerrNieDa
Re: Auto Loop Plugin
Post by HerrNieDa »
you mean something like auto transistion?
there is only the auto transistion on layers... but you can't get the result you are talking about right now...
it was already requested i think 2 years ago ;)
'Noob Loop', ticket #1693, made on April 11th 2011. Currently awaiting an uncertain fate in the dreaded Features Bucket...
damstraversaz
Post by damstraversaz »
that's could be useful !
digital arts:
http://www.damientraversaz.com/#!art-numerique/c1s43
music for dance, documentary and digital arts:
twitchdoktor
Post by twitchdoktor »
you could use autopilot and transitions to work around the issue in this way:
create two instances of the clip in same layer, in columns next to each other. set the autopilot of the first (leftmost) clip to 'play next', and that of the second (rightmost) to 'play previous'. set the layer transition as desired (LIA is a good place to start maybe), set the transition time slider as desired, and finally trigger either instance of the clip. from the manual:
"Tip! This way you can keep switching automatically between two clips, keeping your hands free to improvise on the other layers, or wave to your parents."
NOTE: this will prevent autopilot from 'autopiloting' through the remainder of the layer. if you have many clips you would like to use this workflow with, perhaps you should create a dedicated layer for them, and just remember that you will need to manually select which pair you want to be active. alternately, maybe you could prepare your clips ahead of time in the way you want them (what, you want all the work done for you?!?) ;)
