i just connected 2 Arena Servers with OSC, controlling one with the other. But when triggering a clip on PC1 the clip is also triggered on PC2 but the output is just black. Even if i trigger a clip on PC2 manual on the same layer i can't get any output. The clip is triggered to the layer and plays but just black.
Any help?
BUG REPORT: Black Screen when triggering clip with OSC
Re: BUG REPORT: Black Screen when triggering clip with OSC
there are several topics about this issue, if you use the forum search you will find detailed informations.
In two worlds, it's a known bug.
you solved your problem?? tell me how please ..
thank you very much
thank you very much
