Computer freeze in advanced mode
emendi
Post by emendi »
Hi all.
Im using latest arena version (4.1.7).
Desktop PC with 4 DVI output.
Windows 7.
When I set output to window mode, everything works fine except the fact that every time I open Arena I need to reposition the screen which makes it difficult to be accurate.
When I'm mapping accurately with advanced mode I'm having weird side effects:
- Everything is slower - UI, mouse...
- I don't have access to other windows outside resolume - desktop, mapio2 interface, windows explorer,etc'
after a few seconds fighting with the keyboard (mostly repeating ctrl-tab) I can get to other windows but when Im back in Arena (another ctrl-tab) the other window stuck on top of the Arena but the mouse controlling the Arena UI even do i can't see part of it.
Same composition on my macBookPro works fine but I don't really have the 4 outputs to compare.
Any suggestions?
Thanks ahead.
Emendi.
HerrNieDa
Re: Computer freeze in advanced mode
Post by HerrNieDa »
maybe some issues with the graphic driver?
i suggest you got an ATI-Card :P
maybe an older/newer driver works better ;)
emendi
Post by emendi »
Good idea, I'll try updating the driver and repost soon.
Thanks.
