Advanced Output Zoom /// change Slice transform to crop
Dalien
Post by Dalien »
Hey there,
last Weekend I had a Gig with a very complex mapping / masking. So points, that I added to the mask where so close to each other, so it was hard to choose the correct point for editing. If you would add a possibilty to zoom closer to those points mapping and masking would be much easier.
Some of my Mapping Screens were so close to each other, that the lower corner was visible onto the other screen. I added some transformation points and moved it out of screen. But then I wanted to put two Slices on Top of each other and put them in a triangular shape. It would be really amazing if you add the option to choose between crop and transform. So you would have the possibilty, to shape every slice individually.
This would be amazing !!!
all the best.
Dalien
He2neg
Re: Advanced Output Zoom /// change Slice transform to crop
Post by He2neg »
Also be aware of the copy option for slices. With this You only need to map 1 and u can copy it with another source or whatever you need
But true. A zoom funktion would be nice but is allready in development i think
~Berlin~
Dalien
Post by Dalien »
He2neg wrote:Also be aware of the copy option for slices. With this You only need to map 1 and u can copy it with another source or whatever you need
This is a quite good point. Will try this for my next Gig !!!
Dalien
Post by Dalien »
Ok,
I still got the same problem.
For my last show I build some triangles and sextagon's.
After mounting them to the Wall and starting to map trough the Advanced Output I had the problem
that the shapes were so close to each other, that the corners of the Videoimage are visible on the close screens.
A Mask is useless, cause then you would cover the screen.
The only way by now is to add new points twice and move the edges close to the shape, but with several shapes in your setup and especially with small shapes you won't be able to select the points and to edit them in a clear way.
So how can I cut those edges in a clean way !?
DayVeeJay
Post by DayVeeJay »
x2 on the zoom feature
drazkers
Post by drazkers »
They have confirmed they are working on it in reply to the last 15 threads asking for it.
