Mavericks and quicktime issues Arena
Abstractor
Post by Abstractor »
I've changed the OS to Mavericks my 17" mbp. I'm having no luck running arena on it. just getting the beach ball of death and no chance to select anything in the program.
I've also noticed that since installing Mavericks, opening .mov files requires some "converting" process for quicktime, especially ProRes files (which may not be totally relevant here). I'm not sure what's going on across the board. It's been out long enough for fixes to have come through and still having these problems.
Anyone else have the same issues or any thoughts?
Re: Mavericks and quicktime issues Arena
The Quicktime issue is well known. I've taken the liberty to use this forum's search function to find a few threads discussing it for you:
viewtopic.php?f=12&t=10713&p=42346&hili ... cks#p42346
viewtopic.php?f=12&t=10882&p=43157&hili ... cks#p43157
viewtopic.php?f=12&t=10850&p=42994&hili ... cks#p42994
If you are having trouble with Resolume itself, the best thing to do is to follow the steps on the FAQ: http://resolume.com/support/
If you are still having trouble after the first few steps, the FAQ will tell you how you can contact us and send us your logfile.
