hello
i am sending to my capture card (avermedia c127 ) a display with 1024 x768 but resolume only has 640 x 480 as input.
i dont have the posiblity to change the resolution . anyone knows a good capturecard that resolume can handle higher resolution ? i need especial 1024 x 768
i
						Capture Card Avermedia c127
Re: Capture Card Avermedia c127
For capture cards which are not natively supported in Resolume, you may need to set the composition size to 1024x768 to capture at that resolution.
Hope that helps!
						Hope that helps!
problem solved . the composition was not the problem. the avermedia c127 is not good compatible , but the c199 is perfect ! works perfect ! $ 269.00
corction the card is DarkCrystal HD VGA Pro (C199O)
