Hey,
So I am trying to use 50 mask blend mode on my Layer 4 with some basic black and white videos we made. All the other layers are set to ADD. What I want to accomplish is have the visual on Layer 1 only show through the white parts of the 50 Mask on Layer 4. It is correct on my output monitor display within Resolume, but the image being projected is not correct. It looks as if its just 1 layer on top of the other, nothing showing through. I have seen this done before with our same visuals, but when I try on our system it doesn't work. Any thoughts?
Output Monitor Different Than Output
Re: Output Monitor Different Than Output
Are you using the advanced mapper?
Also are you using a Mac book with integrated graphics?
It sounds like there is some layer to slice routing happening in the Advanced Output. What happens if you reset the Advanced Output to default?
