Is there a way with this card to output just the preview window? ie see the interface on the laptop and only the output screen on the beamer?
so far with the geforce fx5200 i have to set nview to clone to get an output to the beamer...
hmmm any help appreciated,
thanx,
a
geforce fx5200
Anonymous
fx5200 on XP
If you have XP, and the beamer connected, when XP boots, it will initialize the card in dual-screen mode that is accesible from display properties. If you see two screens on the settings tab, then XP has initialized the second output. Resolume runs great in this mode, once you've gone into screen setup and set the second output to fullscreen.
Anonymous
heh thanx for the reply....
I still seem to be having problems though...
firstly i only seem to get output to the projector if i set nView to clone ( with 2nd monitor set to 1024x768), im pretty sure i need to set it to standard( dual monitor) ?
When i set it to this i get no output 2 projector
2ndly are you talking about resolume V2 or V1.5...?
right now im trying it with V1.5
i really appreciate any help here!
thanx,
a
thanx,
a
