Odd BMD bug
dirtyjohn_lv
Odd BMD bug
Post by dirtyjohn_lv »
Been trying to capture from 2 different card (3 input sources). 1 Decklink Duo and 1 4k Extreme
When loading clips from Sources I can load Decklink Duo 1 and 2 and modify capture settings. When trying to add the 4k Source I get no options for choosing resolution, only the De-Interlace and Duration settings.
In order to use the 4k Source I have to unload all instances of the Decklink Sources, then I am able to capture with the 4k. Sometimes I am able to load the 4k Source onto a blank deck and it works, but more often than not, it doesn't work.
I can capture with all 3 simultaneously in TouchDesigner and Premiere. Media Express also recognizes all 3 inputs, but can't check for all 3 at once.
Re: Odd BMD bug
We'll look into it, although it's hard to test this without having a 4K device on hand.
In the meantime, could you post a screenshot of your sources tab?
dirtyjohn_lv
Re: Odd BMD bug
here you go
Re: Odd BMD bug
That filename ;)
Thanks, support ticket has been made.
dirtyjohn_lv
Re: Odd BMD bug
I'm not crazy! I recorded the bug in action
https://dl.dropboxusercontent.com/u/713 ... link4k.mov
Re: Odd BMD bug
Thanks very much for the video, it's always helpful to see a bug in action.
