Had a job this weekend wich involved lipsyncing an animated 3D head (moving mouth) with a vocalist. Would have been very handy to be able to pitch bend (like you can with most cd-players) + or - when the vocalist is going a bit to fast or to slow.
I used multiple cuepoints but that wasn't sufficient enough.
pitch bend
Re: pitch bend
Why don't you just use the global speed on a fader? Just flick the fader up and back to neutral. Thats how I did it on 1200's back when i spun.Thelooca wrote:Had a job this weekend wich involved lipsyncing an animated 3D head (moving mouth) with a vocalist. Would have been very handy to be able to pitch bend (like you can with most cd-players) + or - when the vocalist is going a bit to fast or to slow.
Re: pitch bend
or map a jogwheel to the clip's timeline
