Transistions between (some) clips in a layer
Mayaand
Post by Mayaand »
Is it possible to do specifik transistion for some clips playing in a layer ? and leave the rest alone.
And the same with the auto pilot actually, so i can have a series of clips that play and then end with a loop, and then manually trigger the next one in the layer.
Re: Transistions between (some) clips in a layer
You can set the auto-pilot actions for individual clips by right clicking on the name handle. Auto-pilot will be available from the context menu.
Setting individual transitions is not currently possible.
NexusVisions
Post by NexusVisions »
Mayaand wrote:Is it possible to do specifik transistion for some clips playing in a layer ? and leave the rest alone.
try this http://www.bigfug.com/software/timeline/
