How would you make something like this for a LIVE set?
disconappete
Post by disconappete »
I think this is pretty cool! Looking for advice on how I could build something like this for a live set integrated with Ableton? (link below)
http://www.georgeandjonathan.com/#2
drazkers
Re: How would you make something like this for a LIVE set?
Post by drazkers »
I would head over to touch designer for something like this personally. But you could recreate all of this with a butt load of layers and OSC. You would need the artist to setup a pretty complex setup.
disconappete
thanks for the reply! could you elaborate?
j4s0n.c
Post by j4s0n.c »
Thats all just MIDI notes represented my some kind of 3D comp. No way to do this with just an audio feed.
If all your ableton tracks are VSTs being triggered by MIDI, you'd have to split and send that same MIDI to something like TouchDesigner, and create a bunch of objects that respond to the note/velocity/pitchbend data. Bjork did an album/app Biophilia a while ago that used similar tech...
http://en.wikipedia.org/wiki/Biophilia_(album)
hive8
Post by hive8 »
Personally I would do that in TouchDesigner too, getting all the right frequencies or midi notes and add them on a 3D scene with triggering the specific elements in position and length.
