DXV not available in Adobe Media Encoder CC
ewerx
Post by ewerx »
I recently installed the latest Adobe Create Suite, which comes with Adobe Media Encoder CC. I was hoping to use this for easy batch converting to DXV format, but it is not listed as one of the available codecs.
I tried reinstalling the codec, made no difference. It does still show up on MPEG Streamclip on my machine, so I know it's there and working. Anyone else have this issue?
Re: DXV not available in Adobe Media Encoder CC
dxv is a codec in quicktime
select quicktime format from the list, and then click export settings, select video tab , then video codec, there should be dxv
