Maybe I'm an idiot, but how do you MIDI map the Audio FFT Gain Knob? Have been wanting this for ages, can't figure out how to get it working. I don't see any new options for that after updating (and I do have the new FX etc and they all work fine.)
I am probably dumb and just can't find the correct place? Halp?
How to Midi map the FFT gain in 4.1.9?
Re: How to Midi map the FFT gain in 4.1.9?
Mapping the gain buttons is just a matter of entering Midi map mode.
This feature only refers to the individual gain buttons when a parameter is set to animate to FFT input. It doesn't refer to the master input gain in the preferences.
