Im using arena with mac and have used in the past the nano kontroler, yet , I bought version 2 and its laging on the faders. I read here that others had had the same probelm and the sugestion was to remove contextualmidishortcuts.xml and contextualkeyboardshortcut.xml from preferences ...I did this but it changed nothing....
When I start the program/comp and load the first deck, the faders work find, I load a diferent deck and they start to lag, is this something that can be fixed or should I get a diferent controler? Or could it have to do with my files?? Any ideas?
Thanks, VAnessa
						Korg nano kontroler slow faders
Re: Korg nano kontroler slow faders
Hi there,
which version of Resolume do you use?
Greetings
Greetings
 Do you like outlines? Easy Outliner on Juicebar
 Do you like outlines? Easy Outliner on Juicebar -
				patadeperro1
Hello...Sorry, I had not seen the reply, it never made it to my email inbox, anyway, im on resolume arena 4.0...I decided to give up on the korg 2 and went back to korg 1 , which had worked fine for a long time, but now Im also having probelms with it..I map some commands but the mapping gets all confused, replaces keys for others etc...Ive tried with other midi instuments and I get the same error..
Whats going on?
Thnaks, Vanessa
						Whats going on?
Thnaks, Vanessa
