hey folks,
actually I am pending on problem with two HP AMD FIREPRO W7000 setup.
-XGA composition, 6 layers, each routed to different screen wia DP>VGA adapters in XGA resolution.
-DP1 on main card (PCIe 1 x16) connected as control minitor
-DP2-4 on main card (PCIe 1 x16) connected to projectors
-DP1-3 on second card (PCIe 2 x16) connected to projectors
-DP2-4/1 routed to layers 6,5,4 working well
-DP1-3/2 routed to layers 3,2,1 - when I connect any of this, all setup goes crazy wrong with mixed
layers on outputs, shimmering and simply does not work
-all displays same clock on 60Hz..
-checked with all possible drivers, different output connections and combinations, cards positions, dp>vga adapters... nothing helps..
- same tested on same computer with Nvidia GF GTX 780ti + GF 8400GS and working well without problems..
anyone has an idea what is wrong with W7000? as single card is performing very good ..
PC Setup:
-W7 64 ultimate
-I7 6core
-16GB RAM
-850W power source
thx..
roman
