How to access all effects paramters? Some plugins have more than 4, but te window effect show only the first four.
effects parameters
hi,
we only support up to four parameters,
each freeframe host can choose how many they support.
We allways think that simple plugins are better, you don't want to fiddle around too much during a live show. So more then four parameters seems to us a bit too much. But we are thinking of a way to satisfy those that really would want to have more parameters.
cheers
Edwin
cheers
Edwin
here are a few ways/segestions that might work, though they might not be the way you want to have it.
i recon the most compact way would be to have the vars in a vertical alingment, with the name and value underneath. also maybe the sliders could be reduced in size a bit.
another idea is to reduce the size of boolean values to a on off switch, rather then taking up the entire slider length.
or have so you can select what varialbes are shown, rather then having the only the first 4.
or, have multiple tabs for all of the free frame efects.
im sure you will find a good way to do it.
