I am having a problem that Resolume Arena 4.1.11 is only opening the interface at a scaled down resolution. The output menu reports display one as 1600 x 900 rather than the laptop''s native resolution of 3200 x 1800.
I thought version 4 could handle high resolutions. I haven't had any trouble with outputting to large width setups before. Such as 3072x768.
It is XPS15, i7, Nvidia 750M, Graphics Card drivers updated today.
I am going to see if it works connected to an external display. But I want to be able to use the touch screen on this laptop. Resolume is why I bought this particular machine.
Cheers,
Jason
Resolume interface at lower resolution than screen.
Re: Resolume interface at lower resolution than screen.
O.K. Solved my own problem. There is a setting in windows for an application that is to scale the display for high DPI settings. If I disable this then I get the 20 columns of clips to choose from at once. I expect I will not always want this this setting enabled, but it is good to have the choice.
