windows thunderbolt
windows thunderbolt
Has anyone used a black magic thunderbolt with a pc? Black magic says its possible and my new motherboard is one of their approved ones. But I thought I'd ask on here to see if anyone has tried it before buying said capture card.
Re: windows thunderbolt
Which capture card from them are you trying to buy? I personally would stay away from them and look at this solution, a member did a review on it.
http://www.magewell.com/hardware/dongle ... ml?lang=en
Resolume uses the API/Drives (i'm no developer) from BlackMagic. I vote for the BM card.
Hi.
I have Asus G75 with Thunderbolt and it works fine with BM Intensity Shuttle.
Simo
http://www.randomdoctors.com
VjFinland
Simo
VjFinland
suvanto wrote:Hi.
Simo
VjFinland
Did you have to do anything special to get it to work? I know my machine recognized the shuttle because when I plug it in the thunderbolt window pops up and says bm intensity shuttle active. But when I go to sources in resolume it isnt there
