We need a Live Twitter Meter which could be integrated in Resolume. If its quartz then it will be better. What the meter will do is show number of Tweets for a particular #
Should refresh live.
We would able to edit the hashtag and duplicate the file.
It will be a simple circle on which there will be changing numbers. I have a budget of $800
Live Twitter Count
Re: Live Twitter Count
You can contact me at soham.sarcar@gmail.com
Here is a couple suggestions:
Mac: have you considered using Syphoner to input the Twitter window from your browser? You can crop the image down to the exact content you need - cost $30
Mac/PC: a USB3 or PCIe capture card and a feed from another computer via HDMI - cost $200 on up depending on the card and I'm sure you have a computer laying around.
Will you share your solution when you found your preferred method?
Frédéric
Frédéric
This post is closed, we have been contacted by a developer who is doing the job for us. Will update it here once done.
manuelgazzo
So?
was the job done?
did it work good?
was the job done?
did it work good?
