hy, is it possible to get a live video signal into arena and the black magic Intensity Shuttle Thunderbolt on the macbook pro 2012?? It does not have to be HD. I dont want to buy and then it does not work!
Prozessor 2,3 GHz Intel Core i7
Speicher 16 GB 1600 MHz DDR3
Grafikkarte NVIDIA GeForce GT 650M 512 MB
Software Mac OS X Lion 10.7.5 (11G63b)
live input on macbook pro with intensity shuttle??
Re: live input on macbook pro with intensity shuttle??
It works on the earlier retina with the two thunderbolt ports. I think I was running 10.8.2. It's been awhile since I used it after it bricked itself during a software update (don't let your thunderbolt cables come loose kids).
Cheers.
Cheers.
It will only work if your computer has a thunderbolt port not just a mini DP. The BMD TB
shuttle works on the pcie side of the thunderbolt so give apple a call to 2x check.
